How to manage users for a project
Harshraj pawar February 21, 2019
In my Jira i have 10 users and 5 project . I want that the project which i was assigned to that user only he can see or edit , but all the other user will not see these project and also not edit or do not do any thing
Joe Pitt
Delete is delete. You can't control by issue type.
That said,
Do not delete issues. When you delete it is GONE. Hardly a week goes by without someone wanting to restore an issue. Deleting issues will come back and bite you when it is the most inconvenient. I suggest closing with a resolution value of Deleted anything you want to delete. I implement a special transition only the project lead can execute and it requires filling in a reason field from a select list (such as entered in error, OBE, Duplicate, Other) and explanation text.
Deleting issues destroys historical data. Missing issue numbers will eventually cause a question about what it was and why was it deleted even if it was done properly. Missing data always brings in the question of people hiding something that may have looked bad.
The only viable way to restore an issue is to create a new instance of JIRA and restore a backup that has the issues. Then export them to a csv file and import them to your production instance. You will lose the history.
Sir , i want how i am restrict my user to donot see or edit the project which he was not invited in these project or not add .
or please give me all the steps how can i am create a project where only those user can see or edit which i was assigned
Joe Pitt
You need to configure permissions.
First, by default JIRA has a horrible permission scheme that violates security best practices by allowing everyone that can logon to do just about everything.
JIRA works by GRANTING access. You can't restrict access. By default, it grants access to the group used to logon (see Global permissions to see the "can use" groups and admin groups).  This is where users are getting the access from.
  1. The FIRST thing you need to do to get control is to remove any groups with logon privileges from the permission scheme. unless you absolutely want everyone to have that permission.
  2. Then I suggest you setup Project Roles for the various functions like, tester, QA, Browse Only, etc.
  3. By using roles one permission scheme will cover all projects. The project admin controls project role membership
  4. If the project leads want everyone that can logon access to the project they can add the logon group to a project role with the desired permissions.
This may be a big effort, but it will pay off down the road by making it easy to control access.
Most of the 'old timers' use project roles. It meets the best practice for security and gives complete control to the project lead for access to their project. JIRA comes with many project roles, but you can add more if you have a special need.
