How to migrate data from Prod Jira to Dev Jira in linux environment
kedar
please share the document
Vickey Palzor Lepcha
May 30, 2018
  • Just take an export backup from Prod and Import the same to Test.
  • Attachments - copy the folder manually.
  • After import, log in and reconfigure settings and sorts.
Validate - base url, ldap settings, licenses and so on, check applinks if any .
kedar
why to validate the Base URL and how i can validate it and we don't have LDAP We are using Active Directory
May 30, 2018
Just a check my friend - just check the system info and see if it's the right base url - test base url and not prod base url.
LDAP is a type of Active Directory solution - just validate that it is pointing to the correct AD and not the Prod AD.
These are just check you need to be sure that no PROD configurations are retained in Test.
Application Navigation - see the urls of those applications( if configured)
Check your list of whitelisted urls or ips
kedar
Thanks a lot i want one more help
In Linux server how we will copy the xml backup and Attachments from Prod jira linux server to Dev jira linux server.
How i can migrate Prod Jira Data to Dev jira in Linux.
May 30, 2018
  • For xml - user your JIRA admin console to export and import
  • For attachments - simple linux commands for copying from one server to another ( hope you are aware of where attachments are in a JIRA environment)
kedar
Attachments will b in /opt/ data only or some other place and
How i can copy backup xml file in export  prod jira linux to import dev jira linux.
Why because exported while should be in both prod and dev jira then how we will copy this file in linuxLservers
Kian Stack Mumo Systems
https://confluence.atlassian.com/adminjiraserver071/migrating-jira-applications-to-another-server-802592269.html
This document outlines a general process for moving. It's not a terribly complicated process:
1) Back up production JIRA using XML backup
2) Zip up data directory (attachments, avatars)
3) Restore JIRA on test using XML Backup from prod (make sure you will be able to log in when this is done, make sure test is on same version as prod)
4) Copy attachments and Avatars from production to test server
5) Be sure to update base URL, disconnect incoming mail handlers from production.
It's not terribly difficult.
kedar
In Linux servers how we will copy the xml backup and Attachments from Prod jira linux server to Dev jira linux server.
kedar
Please look my server details of both dev and prod jira space details.
Csdajira01 is dev jira and cspajira01 is my prod jira .i didn't find any attachments in /var/ .
I finded attachments in /opt /attachments which is NFS node point but this /opt/attachments contains bit bucket attachment,confluence attachment,jira attachment so how i have to move this attachmnets to dev jira .please have a look at attached snapshots and do a need full help.SAVE_20180531_105458.pngSAVE_20180531_105359.png
