Hi Mathew,
Yep, you can do that. Just follow this handy guidance:
@John Funk is entirely right. Do read the Things to keep in mind if you migrate from classic to next-gen thoroughly before you make the move!
This seems like the most logical option...I've also experimented with the more manual option of exporting/importing via CSV. Has anyone tried that method?
