How to move epic from one project to another project
Marcin Szarek
Can you please tell me how to move epic from one project to another project?
Thanks in advance.
6 votes
Thomas Schlegel
Hi Marcin,
simply use the move functionality as with every other Jira issue:
Jack Brickey
test <-- this to get me by the spam bug
ok so now for my real question...
@Thomas, , what happens if the epic has associated stories/tasks? Assume you have to move separately and re-associate?
Like korsuk likes this
Thomas Schlegel
they keep their associations. It's a little bit strange then - the Epic is in the new project, the associated story in the old one.
You have to move the story also. But moving a story moves their task also.
(I can't add the 'at Jack Brickey'-tag  - invalid HTML...)
Jack Brickey
thanks. makes sense so now we know...
yep same thing.
Kim Pham
December 18, 2018
Can you move an EPIC from one board (i.e., created in one board) to another board of the same project?  thank you
Jack Brickey
@Kim Pham, yes you just need to update your board templates such that it is removed from one board and appears on the other.
mchang
For what it's worth, as of Jan 2021 I found that Jira Cloud will prompt you to include child stories when moving an epic from one project to another. See screenshot below.
driftjira.atlassian.net_secure_views_bulkedit_BulkMigrateDetails.jspa_singleIssueId=42588.png
The result is that the epic and child stories are migrated all into the new project with the parent-child relationships intact.
Like # people like this
Richard Bowen
March 11, 2022
Is there a way to migrate closed epics from one board to another?
Like Josh Simnitt likes this
Robin Chacko
July 12, 2023
"Move" the whole Epic or a Bug or Story under other projects:
