I have added a number of stories to the backlog of a sprint project in a next-gen cloud account.
None of the stories are allocated an Epic. I am trying to order the backlog but if I just simply drag and drop a story to a higher priority, it snaps back to where it was. If I use the "send to top/bottom" of the backlog, it stays there, but this means the only way I can see to order the backlog is to send to the top in ascending order of priority, each time I send an item to the top, it shuffles everything down. I can do that for the hundred-odd stories I have currently (even though that would be tedious), but if I wanted to add a new story in the middle of the ranking, I won't be able to without re-ranking the whole of the backlog.
Am I doing something wrong, or is this a big flaw in next-gen?
I cannot replicate the behaviour in our instance where drag/drop works fine - it might be a per-site issue.
I found a recent bug for this - see JSWCLOUD-18831 created yesterday - worth voting / following on this one.
You could also try contacting https://support.atlassian.com/ - see this answer from Andy at Atlassian for more details
Ste
Thanks Steve. What kind of license do you have? Ours is an evaluation license (limited to 10 users), could this be the issue?
Hello @Mike Wilkins ,
It seems that this is a feature to be developed, you can vote for the following ticket:
