How to populate text field by using another field value in jira cloud using script runner
Pathan Zubair Khan
Thanks in advance.
Text field to be populate when i select the checkbox field with script runner. As i know behaviors not present in cloud script runner. Any one help me, how to achieve this.
Bill Sheboy
December 11, 2020
Hi @Pathan Zubair Khan
Have you considered using the built-in automation rules instead to make this change for the text field?  Here is a documentation link if you want to consider it:
https://support.atlassian.com/jira-software-cloud/docs/automate-your-jira-cloud-processes-and-workflows/
Best regards,
Pathan Zubair Khan
Hi @Bill Sheboy
Thanks for the suggestion. I have not found the behavior automation.
Bill Sheboy
December 14, 2020
Are you noting that you were not aware of the automation functions, or that you cannot find them?
For a Classic Project, you may find automation rules with:
  • Project Settings > Automation
For a NextGen project, you may find them with:
  • Select the lightning bolt icon (automation) > Manage Automation Rules
