How to prevent issues from being opened after a certain date
James Chen October 8, 2021
Hi all,
I want to add a restriction to avoid an issue be reopened after certain date. That's say, if an issue was closed more than X months, then it cannot be re-opened. The problems is that I cannot find the issue close date field in the conditions or validators. Do you know where I can find this field or how to set this restriction?
Thanks.
Trudy Claspill
What Condition and Validator options do you have at your disposal?
James Chen October 12, 2021
Hi Trudy,
I have "Compare two values", "Date compare validator" and "Dare window validator" that related to "Date" in Validator. But no one has a "closed date" field.
Bill Sheboy
October 8, 2021
Hi @James Chen
Have you tried using the Resolved date/time field in your validator?
Hi Bill, I’ve tried. But I found that the resolved date is not equal to the closed date…for example, sometimes the issue is resolved (or verified) but it is not closed until a few days later, so it it not accurate to use resolved date in these cases…
Bill Sheboy
October 8, 2021
I am not familiar with the Closed field.  Is that a custom field your team has added, a status in your workflow, or something else?
That is a status in our workflow. When issue is verified and go live, we can change the status to "close" this issue.
