My use case is sort of unique, since i never saw any discussion regarding that:
Business Rules:
1. We have 2 subtask issue-types available (lets call them: SType1 and SType 2) for the standard issues in a project
2. SType1 is always created manually by testers
3. Automation rule:
- When SType1 is created
- Create SType2 for the same parent
- Set Summary of Stype2 as (VERIFY - Summary SType1) we use this lane for a summary -- {{issue.fields.summary}}
Everything works correctly, however smart value always picks summary of a parent issue and not the trigger issue.
Please let me know if anyone has encountered this before. We need to reference a summary of a subtask that triggered the rule and not a parent issue.
Thanks in advance,
Alex
{{issue}} always refers to the current issue within a branch when you are in a branch. Since you used a branch to access the parent issue, {{issue}} refers to that parent issue.
If you want to access data from the trigger issue, use {{triggerIssue}}
{{triggerIssue.fields.summary}}
