How to restrict component values based on issue type
priym
We want restrict the component field values based on issue type.
For Eg. If we select issue type as A then component values should be a and b. If we select issue type B then component value should be c.
Is it possible to achieve using behaviours.
John Funk
Hi Priym,
You will not be able to do that with Jira Cloud out of the box.
priym
Hi @John Funk , Thanks for your reply. Is it possible in Jira Data centre?
John Funk
No, I don't believe so.
