  • Community
  • Q&A
  • Jira
  • Questions
  • How to retrieve a custom field values from several linked issues and present it as list in one scripted field?
Eitan Gur
Hi
I'm trying to activate a scripted field that will retrieve a custom field value from several linked issues (different link types - Parent of, Child of etc..) and present the scripted field values as a list of values (as a string/list).
Trying the following code which gives me only one of the wanted values (the value from the last linked issue):
import com.atlassian.crowd.embedded.api.User
import com.atlassian.jira.issue.CustomFieldManager
def Issue issue = issue
def user = ComponentAccessor.getUserManager().getUserByName("admin").getDirectoryUser()
def issueLinkManager = ComponentAccessor.issueLinkManager
def linkCollection = issueLinkManager.getLinkCollection(issue, user)
if (linkCollection && linkCollection.allIssues) {
def CustomFieldManager customFieldManager = ComponentAccessor.customFieldManager
def customField = customFieldManager.getCustomFieldObject("customfield_xxxxx")
def linkedIssue = linkCollection.allIssues.first()
return linkedIssue.getCustomFieldValue(customField)
Vasiliy Zverev
December 15, 2015
  1. You miss a brasket into the very end of an issue.
  2. Try using methods to get value. E.g. linkCollection.getAllIssues(), but not allIssues
To speed up development see this:https://answers.atlassian.com/questions/32982259
I modify it a little to get value from first linked issue into list.
def Issue issue = issue;
def user = ComponentAccessor.getUserManager().getUserByName("vzverev").getDirectoryUser()
if (linkCollection && linkCollection.getAllIssues()) {
        def customField = customFieldManager.getCustomFieldObject("customfield_xxxx")
    	for(Issue curLinkedissue: linkCollection.getAllIssues()){
           	return curLinkedissue.getCustomFieldValue(customField)
Vijay Sv
Hi Vasiliy,
I am pretty stuck with a similar issue, is there a way we get custom field values from multiple linked issues(not just first linked issue custom field value).
Vijay
Eitan Gur
Thank you Vasily,
Your help was very useful and I eventually used the aforementioned code with a little addition and it works well:
def user = ComponentAccessor.getUserManager().getUserByName("xxxxx").getDirectoryUser()
def references = []
def curValue
curValue = curLinkedissue.getCustomFieldValue(customField)
if (curValue != null) {
references << curValue
String poReferences = references.join(",\r\n")
return poReferences
Vasiliy Zverev
December 16, 2015
Perfect!
