How to revert changes for project
Yash Pradhan
hi by mistake, I have changed the workflow to all 1200+ projects. can you tell how to Reset it back
Dave Mathijs
Hi @Yash Pradhan ,
Did you take a backup copy of the previous workflow?
If yes, associate the old workflow to the designated issue types in the Workflow Scheme and publish the Workflow Scheme. Then you'll need to possibly map some statuses again. Jira will do the rest for you.
If you didn't take a backup of the previous workflow, you'll have to recreate it by taking a copy of the current workflow and editing the inactive workflow. After that, follow the procedure above.
Yash Pradhan
Yes, i do have backups
Like Dave Mathijs likes this
