How to search JIRA by providing an Issue ID?
wajdhaikal
March 12, 2012
I need to search for an issue using its ID and get statistcs. How to do his in JIRA?
10 votes
Tom Jackson
January 29, 2014
this jql works too: id=<issue id>
3 votes
Renjith Pillai
March 12, 2012
You meant the issue key as ID? If that is the case then you can get this using JQL, issueKey = "your issue id" or if you have multiple issues issueKey in (ids...).
3 votes
Mizan
March 12, 2012
By id i assume the issue key , you can simply do a JQL search .. example: id= ABC-1
Deleted user June 18, 2013
If you know the ID and want to browse to the issue you can use the url like this:
http://myjiraserver/secure/ViewIssue.jspa?id=ISSUE_ID
Phillip Ponzer [Cprime]
January 26, 2015
This answer no longer appears to work even on Atlassian's instance of JIRA. See [JRA-41720|https://jira.atlassian.com/browse/JRA-41720] for more information.
Robert Knox
June 21, 2016
If searching for multiple id's, perhaps to make a gadget on a dashboard, you can do a JQL Search id in (abc-1,abc-2,abc-3)
Renjith Pillai
March 12, 2012
The right top box, Quick Search :)
RobertC
May 14, 2019
Adios to that
Gunaseelan Ramalingam April 30, 2021
This is most ridiculous thing that i had ever heard. Unable to search an issue with issue id. atlassian needs to fix this ASAP
hob
I am pretty shocked that if you know the issue ID, such as XYZ-123, there is no easy (beginner user) way to find it.  The search feature has a text box which I would expect to search the Id field, but it doesn't. The advanced search feature also has no access to the ID field.
There seems to be no way to star or some how save an issue, so when I want to find it again, i have to save a link in notepad or similar, then paste it back in.
At any given time, I an switching back and forth between a hand full of issues, but there is no way to mark them or find them again when I them.
I spend literally hours a week trying to find issues which I was dealing with say 30 minutes ago, but have no way to star or search given I remember the issue id number.
I dont really want to have to start learning jql.  This should not be a requirement for lay users.
hob
Someone showed me a hack way to "star" important issues.  That is to create some jql along the lines of "key in (ABD-234,ABD-342)", save it as a named query, then star this query so it shows up on the left.  I dont know why Atlassian dont allow you to star an issue.
RobertC
May 14, 2019
Latest and greatest Jira (cloud) no longer has this "Quick Search on the top Nav Bar"
SO PLEASE JIRA SUPPORT: WHAT IS THE QUICKEST WAY  to simply find/jump to an item with ID regardless of it's creation date & status
Raphaël Ruis
May 31, 2019
Yes please, I find it incredible that we have to write a JQL query to chieve that.
Ben Thomas
Still not fixed.
Scott DeLoach
October 22, 2019
Looks like the quick search has been moved to the left nav bar - look for the magnifying glass and enter the ID and hit enter - that will take you directly to the issue.
Ben Thomas
Right you are @Scott DeLoach . I just can't get the hang of using the left nav - expect those things to be on top somewhere.
Andrew Scales
November 5, 2019
The magnifying glass button search only half works - if you type in a specific issue ID you get results of tickets that contain this ID in their description,  but,  incredibly,  it still doesn't always find the ID.  Seems hard to believe that this most basic of functions is not straightforward.
Kyle Mitofsky
A much simpler answer is to use Quick Search on the top Nav Bar!
The Quick Search box is located at the top right of your screen. If you type in the key of an issue, you will jump straight to that issue. For example, if you type in 'ABC-107' (or 'abc-107'), and press the Enter you will be redirected to the JIRA issue 'ABC-107'.
wajdhaikal
March 12, 2012
Yes you are right :)
wajdhaikal
March 12, 2012
There is no way to have a search box where I paste the issue Key, and it search whole jira? any plugin?
