how to separate the custom field configuration it was shared by 31 projects i need to separate that field schema ???
Hello @Lekkala Chandramouleswara reddy
You'll have to split 2 schemes:
1. Field Configuration
2. Field Configuration Scheme
For that, click the cog wheel in the upper right corner and select - "Work-Items"
In the left menu, navigate to Field Configuration Scheme".
Find the default scheme and copy it, this will create a copy of the scheme, next you'll need to see which Field Configuration it uses - and copy it also.
After copying the Field Configuration add it to the copied Field Configuration Scheme.
Then simply go to your project settings and select Field Configuration Scheme and on the 3 dots, select to change to a different scheme - and thats it.
Hope that helps.
Ariel
