Hello!
At the moment we have a sprint board set up with 5 columns. There are tickets we want to track across the sprints, however they are likely to be actioned slowly over a few sprints so we don't want them cluttering up tickets we action daily.
Is it possible to have a kind of "separator"? So have the tickets in the exact same board that follow the same workflow, but have the tickets further down the page, separated by a line or a bar of some kind.
I've attached a hi-fi mockup of the kind of thing I'm aiming for.
Thanks in advance for your help guys.
Hi @Jon_Fister ,
You can try to categorize daily and monthly ticket by label or other methods and use the Base Swimlanes on query to show it.
I managed to do it using this!
Thank you so much.
I had already put labels on them as well as created a new issue type for them, so it was quite was to just create one query based on "Type is (every type except monthly)" to have all my daily tickets, then another one using my new issuetype.
