Hi @Fanny JACOB,
The Business Value field is a number field, is your requirement to set a single number (1,2,3,etc.) in the text field, a range (1-10, 11-20, etc.), or change the custom field type so instead of being a number field it is a drop-down/select list field?
Hope this helps
