hi @Santosh Kumar , You can get the salesforce & jira connector from the market place. Hope this should help you.
You can also refer to following url for more details
https://www.salesforce.com/solutions/small-business-solutions/integrations/jira-integration/#
@Haran Kumar i was trying to configure from salesforce to jira using zagile conector for this i was facing issue.
@Santosh Kumar , I can help you by providing you with a demo link. Kindly look into the same and check if you have gone wrong anywhere. It will be helpful for the community to answer and give you the right solution if you can elaborate on the exact issue faced.
Refer to this :https://www.youtube.com/watch?v=ei5Oo-2tmL4&feature=youtu.be
Thank you.
