×Hello @Gal Fatal
Considering that the field is not listed in the Supported Fields page in the ScriptRunner Cloud Behaviours documentation, I don't think you can actually use Behaviours on that field.
Have you contacted Adaptavist to find out if the field is supported for Behaviours?
