How to setup Automation to look for keyword in comments?
Rod March 17, 2020
I am trying to use Automation to look for keyword in the comments field so I can update the status of a JIRA case. Can this be done?
For example, if a comment is updated and if the comments field contains the following words '[Waiting for QA] is changed to [Back to Dev]', I would like to change the JIRA status to 'To Do'.
Thanks.
3 votes
Ajay _view26_
Hi @Rod ,
You can add a JQL condition to the Automation rule to achieve the use-case.
Rod March 18, 2020
Will give this a try.
And to update the workflow status to 'To Do'?
Rod March 18, 2020
Hi, This looks like it is looking for "Waiting for QA" for All comments?
Is there a way to limit the trigger to just the latest comment added?
Ajay _view26_
You can use the issue commented condition
