How to stop Jira from closing issues when merging a Bitbucket Pull Request?
Manuel W_ October 17, 2022
Hi all,
we're using Jira v8.13 and have set it up in a way so we can create BitBucket branches and Pull Requests from within Jira.
Everytime someone closes a Pull Request, the issue gets set to "done". This is one of two final states we have, "done" and "wontfix".
How can I stop Jira doing that?
Often, there are more than one Pull Requests linked to one issue. Currently I have to re-open the issue after every Pull Request merge, which is very annoying.
Manuel
P.S.: I'd like to add that I'm the Jira admin. But I feel very overwhelmed by the amount of configurability there is. I'm a software dev who now takes care about Jira on the side.
Sümeye Beki
Hi @Manuel W_
Jira or Bitbucket does not do this by itself unless you say so. There may be triggers on the workflow. Could you please check the workflow transition's trigger tab?
Hi @Sümeye Beki
I did so -- the workflow transition has no trigger set.
Sümeye Beki
Hmm, then, could you please check your Bitbucket repo for webhooks? Or you may, idk, have post function on your CI tool(Jenkins etc)
Like Manuel W_ likes this
Hi @Sümeye Beki,
I checked BitBake but we don't have any WebHooks active.
This is what shows up in a Jira issues activity tab when a pull request closes the issue:
Automated transition changed the status to Done on BLY-2346 - Headline goes here (triggered when Manuel merged pull request #721 in Bitbucket)
Does that give an indication on what triggers it? The projects workflow is "Software Simplified Workflow for Project BLY" with a note "Generated by JIRA Software version 8.5.0-DAILY20190920183006. This workflow is managed internally by Jira Software. Do not manually modify this workflow."
I checked the workflow steps and found a transition "successful review" on the "Ready For Review" step...
 but it has no triggers assigned. This is likely the transition triggered when clicking the "successful review" button in the GUI.
Sümeye Beki
The projects workflow is "Software Simplified Workflow for Project BLY" but also the issue that is triggered via pull request is using this workflow, right?
Manuel W_ October 18, 2022
Yes it is! Just checked. That's the only workflow active for this project and all issue types are assigned to it.
Sümeye Beki
Okay, what about listeners or Automation for jira plugin? There may be a listener or automation rule for the issue.
Manuel W_ October 19, 2022
@Sümeye Beki I will look into this asap, which won't be earlier than in a few days I'm afraid. I very much appreciate your help and will give notice when I was able to check.
Manuel W_ October 31, 2022
@Sümeye Beki I now checked and can confirm we haven't got any custom listeners (only non-configuratble Jira-internal ones) set up. Also "automation rule". I think Jira Automation got added only later and our Jira 8 doesn't yet support it as I couldn't find anything hinting at that feature.
I found an "Application Link" between BitBucket and Jira with a feature "Smart Commit". I disabled it but it didn't change anything.
Alexandru Magiaru
February 13, 2025
Hello guys!
I just encountered the same issue, 2,5 years later.
@Manuel W_did you somehow manage to solve this in the meantime?
Thank you,
Alexandru
