How to update status using transition using java API?
Ramesh Lakshmanasamy July 20, 2018
I need to update issue using JAVA API.This is only possible via transition id.Please can you put some java code.
Tansu Akdeniz
Hi @Ramesh Lakshmanasamy,
Please take a look at:
Example code;
WorkflowTransitionUtil workflowTransitionUtil = (WorkflowTransitionUtil) JiraUtils.loadComponent(WorkflowTransitionUtilImpl.class);
Map params = new HashMap();
String comment = "abc"
params.put(IssueFieldConstants.COMMENT, comment);
workflowTransitionUtil.setIssue(issue);
workflowTransitionUtil.setUserkey(userKey);
workflowTransitionUtil.setAction(111);
workflowTransitionUtil.setParams(params);
workflowTransitionUtil.validate();
workflowTransitionUtil.progress();
Harsh Dubey-Admin June 10, 2019
It doesn't work.
Christian_Schönert August 28, 2019
Since I was on the search myself, I found this solution (tested with Jira 8.3.0 and 8.3.1):
IssueService.IssueResult transResult;
IssueInputParameters issueInputParameters = new IssueInputParametersImpl();
TransitionValidationResult validationResult =
issueService.validateTransition(workflowuser, issue.getId(), actionDescriptor.getId(), issueInputParameters);
if (validationResult.isValid()) {
transResult = issueService.transition(workflowuser, validationResult);
What you have to figure out yourself is how to get at the JiraWorkflow. I, for example, extract the List by the following:
Collection<JiraWorkflow> workflows = workflowManager.getActiveWorkflows();
where I iterate all workflows and compare to the searched workflow name. From there on you can go through all actions (.getAllActions()) which give you the transition IDs.
My problem is, and I hope maybe someone else can answer it: How do you make a transition comment?
This:
issueInputParameters.setComment("TestComment");
 always gives me the validation error that I'm not permitted to add a comment to this issue, although the workflow user is admin and creator of the actual issue.
Regards
Chris
