How to upload / import an automation in jira
Mehran Ahmadi December 14, 2023
Hi all,
I did export an automation (JSON file) and I would like to know how to import the file again into the automation rules.
Thank you for your time and attention.
Kind Regards
Mehran
Walter Buggenhout
Hi @Mehran Ahmadi,
You would need to upload the file from the global automation rules view. Hit the ... button near the top right of the screen and select Import from the menu there.
After selecting the file, you will be asked to map the rule to the right project, owner, etc.
Hope this helps!
Hi @Walter Buggenhout ,
ok thank you very much.
