How to use Block Kit messages when sending Slack messages through Automation for Jira
Robby Helms
Slack supports sending messages using its Block Kit. Are these kinds of messages supported when sending Slack messages as an action through Automation for Jira?
Daniel Eads
April 1, 2021
Hi @Robby Helms , welcome to the Community!
Currently the setup for Automation into Slack uses the Legacy Webhook app, which doesn't support Block Kit or some other interactive elements. You can read the details on what is / isn't available through the legacy webhook app here. Were Automation to use the newer Slack app framework, block kit elements might be possible. However, this would also remove the ability to use a channel override in the webhook parameters.
We've got an issue in Automation's backlog to migrate off the Legacy webhook app, which you can view here: https://codebarrel.atlassian.net/browse/AUT-1515 I should note that this issue exists on the codebarrel tracker (before Automation was wrapped natively into Jira Cloud), so unfortunately you'll be unable to vote on or watch this particular issue, as you would be able to for issues on jira.atlassian.com.
Daniel | Atlassian Suport
Trong Duc Truong
February 7, 2024
Hello @Daniel Eads, I cannot seem to be able to view your  https://codebarrel.atlassian.net/browse/AUT-1515, is automation still using the legacy webhook app or have they switched to the newer one?
Bill Martin March 13, 2024
also looking for this - I'd like to send an inline image icon in a message from jira
Julien Gomez
March 21, 2024
Hi @Daniel Eads, same needs here, please give us an update on the current support of this feature, best regards, Julien
Callum Lawrence
April 11, 2024
Me too, is this still not supported 3 years later?
Robert Newton August 26, 2024
Hello, can we get an update on where this feature is at in 2024?
Kathryn Kosey
I was about to post in here too, then discovered the announcement that it's now supported! 🎉
https://community.atlassian.com/t5/Jira-articles/Elevate-Your-Slack-Messages-Advanced-Message-Formatting-with/ba-p/2805478
Like # people like this
FREE
