In my current organization we are using Jira for bug reporting . We would like to use
JIRA for maintaining manual test cases also. How Can We use it?
Look at Zephyr or Testrail - both seem like good solutions that integrate well with JIRA for test management.
Thanks Steven for your help. I just tried Testrail. I will try Zephyr.
you're welcome Shraddha!! the company I used to work for used Testrail and they're in the process of switching to Zephyr as it's cheaper and seems to have really good JIRA integration.
Welcome to the Atlassian Community.
For Test Management, I really like QMetry for Jira among the all test management apps which has end to end traceability, Import/Export capabilities and very user-friendly in terms of overall test management purpose.
@Shraddha Nalawade , our QA team recently moved to Jira for test management, we are currently using a tool called synapseRT. It is really a good tool and the support response is very fast! The tool is quite easy to learn if you are ISTQB certified or experienced TestLink.
Hope it helps.
Paul
