How to use same test cases for different browser for cross browser testing?
Krinal Pathak
February 16, 2021
For example I have a same Test steps in my test case to test different browsers like chrome, Firefox, IE . How do i execute the same test case and demonstrate that i have validated it for all browsers?
I don't want to create so many duplicate test cases for different browsers, At the same time i want to display i have covered all the scenarios
Ravi Sagar _Sparxsys_
February 16, 2021
Hi @Krinal Pathak
Are you using any app for test management? In apps there is a concept of test run for that, so you run the test for each environment.
Without using an app you can achieve that by using a custom field to capture the environment/browser or use a checklist.
Ravi
Krinal Pathak
February 16, 2021
Thank you, This is helpful.
