How to use script JQL function with regex in groovy script
SWAPNIL SRIVASTAV
When I am using '$' sign in groovy script for behaviour in jira, I am getting compliation error.
Objective: Trying to validate summary field. Not allowing duplicate summaries. Searching the exact text in summary and making it case-insensitive search.
JQL query which is working fine in Issue Navigator:
issueFunction in issueFieldMatch("project = "ABC and key !=AB-1", "Summary", "^(?i)Test$")
Script I tried:
import com.atlassian.jira.issue.searchSearchProvider
import com.atlassian.jira.jql.parser.JqlQueryParser
import com.atlassian.jira.web.bean.PagerFilter
import com.atlassian.jira.issue.Issue
def summaryObj = getFieldById(getFieldChanged())
def summary = summaryObj.getValue()
def jqlQueryParser = ComponentAccessor.getComponent(JqlQueryParser)
def searchProvider = ComponentAccessor.getComponent(SearchProvider)
def issue = underlyingIssue
if(issue == null)
     return
def user = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
def query = jqlQueryParser.parseQuery("issueFunction in issueFieldMatch('project = Cluster and key!= "+issue.key+"', 'Summary', '^(?i)"+summary+"$')")
if(results.getTotal()>0)
     summaryObj.setError("Issue Summary already exists.")
else
     summaryObj.clearError()
I am getting error in the line I have made bold as Illegal String Body character after $ sign. I think it is because groovy performs String Interpolation also using $ sign. How to get the JQL accepted in this script?
Kindly help.
Thanks and Regards,
Swapnil Srivastav
Damian Wodzinski
December 6, 2019
Use \ before any character that can be interpreted improperly. So it would be:
def query = jqlQueryParser.parseQuery("issueFunction in issueFieldMatch('project = Cluster and key!= \"+issue.key+\"', 'Summary', '^(?i)\"+summary+\"\$')")
I do not know if you need to do it before ' characters, you need to check that.
I made similar one:
def query = jqlQueryParser.parseQuery("issueFunction in commented(\"by ${person} after startOfDay(-1d) before endOfDay(-1d)\") AND project = \"PCS\"");
SWAPNIL SRIVASTAV
Hello @Damian Wodzinski ,
Thanks for your response.
I tried using \ and \\ before $. Both do not give a compilation error but do not get the task done.
I guess that is because the regular expression meaning is altered in that case.
Swapnil Srivastav.
Damian Wodzinski
December 6, 2019
Why dont you put Regex as variable, and then add reference to your JQL part in script?
SWAPNIL SRIVASTAV
Could you please let me know how to do that.
I have not worked with regular expressions before.
Thanks and Regards,
Swapnil Srivastav.
Damian Wodzinski
December 6, 2019
Can you paste the whole JQL commend directly from Jira? Is it working there?
SWAPNIL SRIVASTAV
Hi @Damian Wodzinski ,
Yes it is working there. I cannot paste data from JIRA. Here is the exact JQL
Thanks and Regards,
Swapnil Srivastav
Damian Wodzinski
December 9, 2019
Use that:
def query = jqlQueryParser.parseQuery("issueFunction in issueFieldMatch(\"project = 'ABC' AND key != AB-1\",\"Summary\",\"^(?i)Test\$\")")
SWAPNIL SRIVASTAV
JQL:
issueFunction in issueFieldMatch("project = ABC and issuetype = "DE", "Summary", "^(?i)Test$")
and for groovy:
issueFunction in issueFieldMatch("project = ABC" and key != ${issue.key}", "Summary", "^(?i)${summary}\$")
works fine for me.
Thanks a lot for your response
Best Regards,
Swapnil Srivastav.
Joe Pursel
Hi @SWAPNIL SRIVASTAV ,
Thank you so much for the example you provided showing how to use the subquery by including multiple parameters.
Using your example and fitting it to my use case made all the difference between the query timing out and running amazingly fast.
My use case was
issueFunction in issueFieldMatch("project = ACT AND labels = S4WW AND summary ~ lifecycle.intake.firstkick", "description", "intake_date => 2021-04")
Best Regards,
Joe
Like SWAPNIL SRIVASTAV likes this
SWAPNIL SRIVASTAV
Hi @Joe Pursel ,
Glad to help. Feel free to click on the Like button next to my comment :)
