JQL for my filter is:
project = test and component ~ "Api*"
This does not work . Is there any other way to use it? Please help as grouping my bugs and creating filters has become difficult.
Thanks!
Hi ;)
You can use a FREE app called JQL Booster Pack and use the componentMatches() JQL function to get the requested functionality
• Find issues in components that their name start with 'Database':
component IN componentMatches( "Database.*" ) |
• Find issues in components that their name contais 'screen':
component IN componentMatches( ".*screen.*" ) |
• Find issues in components that their name end with 'Core':
component IN componentMatches( ".*Core" ) |
It was at the time I wrote my comment ...
The following works for me:
component IN componentMatch("Api*")
Thanks! This works well.
I get
Unable to find JQL function 'componentMatch()'.
What plug-in did you use?
Wild card searching is not supported by default for components. You will have to use a plugin like JQL Tricks.
