Hi Guys,
I Have 3 Issue type
issuetype A can triger create Issuetype B and C
the resuld is issuetype can be linked issue A-B and A-C
what I want automate link issue B-C because, if issue B changed status to drop, issue C change to Drop too.
I try to used JMWE Link issues to the current issue post-function in workflow B
and input
JQL expression : issuetype = "C"
after I test it,
Workflow issue B linked to issue C but not from issue C in same project where is it made
the question is, how to make specific project in JMWE-JQL?
How are you creating issues B and C? If you're using a JMWE Create Issues post function, then you can refer to
Best
David
Thanks for the reference,
I used JMWE for create Issue B and C
if Issuetype A created, it triger JMWE for creating Issuetype B and C
and it make link Issue A-B and A-C
what I need to make automate Link issue B-C
B and C create at same time
Tyas
Hi Tyas,
if we assume that your current Iterator is something like:
"summary":"Issue B"
"summary":"Issue C"
which you use to create two issues, each with a different summary.
You can update the iterator to this:
"summary":"Issue B"
"summary":"Issue C",
"issueLinks": [
{"linkName":"blocks","toIssue":1}
This will automatically link issue C to issue B through the "blocks" link type direction.
Hi @David Fischer ,
thanks for your information
like I discribe in my first question, I have 3 Issuetype (All of it different type)
but I thinks you assume B and C in same Issuetype,
I assume, that you are using : Create issue(s) post-function
and "Summary" in your script is from this one? (CMIIW)
And, issuetype A trigger create 2 another issue B and C ( same issuetype) with different summary
but mine is that Issuetype A can create Issuetype B and Issuetype C ( for now I can Create this by JMWE) and what I need to do is automatic to link an issuetype B and issuetype C.
what I described works - you can create both issues using a single Create Issue(s) post-function, by selecting "Calculated" as the Issue Type, with this value:
{{it.issueType}}
and as the iterator, use:
"summary":"Issue B",
"issueType":"Issue type for B"
"issueType":"Issue type for C"
"issueLinks": [
and for the Summary field, use
{{it.summary}}
thanks for the script
I follow your guide,
but, I get error
I try some condition for solving missing Issuetype from
example :
{{ issue.fields.issuetype.name }}
{{ issue.fields.issuetype.name == "Story" }}
please help find what is missing
Tyas
Hi @Tyas Iglecias ,
sorry, I forgot to mention that, since the iterator script returns a JSON object, you need to check the "Iterator returns JSON" option.
Best,
David
Dear @David Fischer
Thanks for your guide it's work,
one more thing we missed was a comma,
and I check from your guide in confluence
its solved my issue
thanks very much
Tyas
I have question,
How to link multiple issue with JMWE using iteration?
Example:
can you help me?
@Rizky.Tuasikal did you read the documentation I shared earlier, and the example above?
If you still can't figure it out, can you open a support request with us: https://innovalog.atlassian.net/servicedesk/customer/portals
