Hi!
I wanted to do a workflow validation where if a ticket does not have the latest unreleased version on it.
I expected that this should be possible at least with PowerScripts or ScriptRunner if not native Jira.
I've had little success:
I tried this:
if(size(key in silJQLExpression('', 'issueKey = ' + key + ' AND fixVersion in unreleasedVersions() AND not fixVersions in releasedVersions()'))) == 0){
return false, "fixVersion", "Fix Versions blablalbla.";
return true;
but it always says there's some error without any further info.
Any hints on how to proceed?
Below snippet will help you to check whether ticket is associated with released version or unreleased one
you can place this in validator or condition(scriptrunner functions)
def versions = issue.getFixVersions()
for (v in versions){
if(!v.isReleased()){
return true // there is at least one unreleased version hence returning true
return false
Hope this helps
BR,
Leo
Thanks, looks great, I modified it a bit further into something like this:
import com.atlassian.jira.issue.search.SearchProvider
import com.atlassian.jira.jql.parser.JqlQueryParser
import com.atlassian.jira.web.bean.PagerFilter
import com.atlassian.jira.bc.issue.search.SearchService
def jqlQueryParser = ComponentAccessor.getComponent(JqlQueryParser)
def searchService = ComponentAccessor.getComponent(SearchService.class)
def user = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
def query = jqlQueryParser.parseQuery("issuekey = " + issue.key + " AND development[pullrequests].merged > 0")
def results = searchService.search(user, query, PagerFilter.getUnlimitedFilter())
if (results.total == 1 && issue.getResolution() in ["Fixed", "Done", "Resolved"]){
if (versions.size() == 0) return false
return true
return false
