How to validate more than one conditions using JMWE
Rosana Casilli
Hello all!!!
I have problems  using JMWE..
I want to add a condition where the  Components should be "Homologación" and Labels should be "MT" in order to transition to next status.
I found in documentation the following expression
{{ issue.fields["Labels"] | find("MT") != null }} btu when testing tit from JMWE  it shows me the following error
There was an error during the execution of your Jira expression
Message:
Jira expression failed to parse: line 1, column 2:
IDENTIFIER or } expected, { encountered.
What should I change? and If I want to add a second condition which is the and operator used?
Thanks in advance
Ro
David Fischer
Hi @Rosana Casilli
the syntax is actually described on the "Issue Fields" help tab at the bottom of the editor. The syntax for Conditions and Validators is different from that of Post functions.
In your case, you want this:
!!issue.components && issue.components.some(it => it.name == "Homologación") && !!issue.labels && issue.labels.includes("MT")
Rosana Casilli
thank you so much @David Fischer  after sending the question I have found the answer
