We are currently using Jira Server and I would like to be able to view how much work was actually logged for all the issues assigned to a given Jira release fix version. Additionally, if there's a way to also view the total of all the original estimates, that would be helpful. Exporting all the issues from the Issues section and then manually adding up the various minutes, hours, days, etc... in Excel is very tedious for the estimates and the logged work is not available as part of the export to CSV from what I can see.
Jeff
Hi @Jeff Hayes
If you would be interested in an easy to use paid add-on to get this data, you can try out our plugin
Agile Tools : Epic Tree & Time in Status
The app provides the following features
Worklogs & Time tracking Report :- Track time spent by resources with multiple filters / category / grouping features. Export to csv format is also available.
Along with this there are multiple other features like Time in Status, Links Hierarchy, Epic Hierarchy etc which the app provide.
The Epic Hierarchy module has the fix version filter. and shows the sum up for time logged at all level with export to csv option as well.
Rahul,
I don't see where the overview for this app shows that I can do these types of things within a RELEASE (i.e. "fix version"). Is that just not mentioned or is it not a feature?
Jeff
Hi Jeff
Thanks for your reply.
In the worklogs report, within Additional Criteria, we have fix version option available.
The Epic Hierarchy screen has a fix version filter too, alongside the project filter.
Also I would request, if we can demo the plugin to you to go through all the features for the app. Our support email id is support@rvsoftwares.in
Rahul
Thanks. At this point, I don't believe we are interested in paid app solutions, particularly on Jira Server since it's being EOL'd. Also, I wasn't able to see your pricing structure, which is also an issue.
Jeff
