How to work out existing installation directory for Jira upgrade?
yannickwilson
December 15, 2019
My Jira working directory and Jira home directory are in different locations
The upgrade wizard asks for 'existing installation directory', how do I confirm which one is correct for the system upgrade?
Alexis Robert
Hi @yannickwilson ,
the installation directory is where you have the Jira binary application. It is different from your Jira Home directory. It will likely be something like atlassian-jira-8.5.x-standalone for example.
Let me know if this helps,
--Alexis
Infra Team
December 16, 2019
Thanks for your input
I am running Windows so the path might be slightly different
But I figured that the directory where the start and stop scripts were would be a indicator
C:\Program Files\Atlassian\JIRA in my instance
