Any suggestions on how I can get to the workflow link?
The first thing you should look at is what type of project you are in, if you look on the left-hand side at the bottom it will say "You're in a team-managed project" or "You're in a company-managed project". Team-managed projects does not currently have a separate menu option for workflows, that is all controlled based on the columns on the board.
Thank you Mikael! Yes, I was in a team-managed project. I have not yet explored 'company managed projects. So now I understand why the workflow link is not visible. Thank you so much!
