I am looking for automation of inactive users in Jira and send notification for those users who have
Vidya VASUDEVAN
I am looking for automation of inactive users in Jira and send notification for those users who have not accessed Jira/Confluence for more than a month.. Can anyone help me with this.. Is there any way to remove the users as its tedious to remove the users manually from user management.  There is a limit for the users in Jira and confluence, however due to budget the limit cannot be exceeded hence I have to remove it manually.. I had proposed the idea to the team.. I have also thought of JQL but still need assistance.
Also Its cloud version.
Can anyone help me here or  reach out to me on linkedn and share some insights on this.
4 accepted
Michal Switala October 3, 2024
Hi Vidya,
Sure it is possible by using smart value :
{{attachment.author.active}}: Returns true if their account is active, and false if not.
however I would need to know when this automation would be triggered also what would be the use case of this global automation. Also what kind of notification would you like to send, email or some Jira notification ?
Please clarify above and I will help you build global automation,
Or you might find this article helpful on just how to remove inactive jira users :
https://confluence.atlassian.com/jirakb/how-to-disable-remove-inactive-or-active-users-in-bulk-1093012826.html
if you find this helpful please mark this post as accepted answer,
Michal Switala
Associate Product Support Engineer at Appfire
Vidya VASUDEVAN
Thank you so much for this information, I need help on this, I would like to send it as email to the inactive users because emails are mostly accessed by everyone but no Jira..
Let me know how can I reach out to you.
Michal Switala October 4, 2024
Hi Vidya,
Sure, I will prepare an automation and show you it here whenever it's ready. Do you have an idea what would be a trigger ?
Michal Switala
Vidya VASUDEVAN
Hi Michael,
Can we connect on some platform, if you are comfortable?
Vidya Vasudevan
Vidya VASUDEVAN
The trigger is ( users inactive more than 1 month) for confluence and Jira
Cristian0791
October 3, 2024
Hi Vidya,
You can do this with python:
1.Download the list with all active users
2.Filter by: Last Seen
3.Send emai to the filtered result.
To do this you will need a python developer.
Vidya VASUDEVAN
Thats a great idea, then I have to look for phython developer in my project which is near to impossible due to budget constraint..Let me see on site developer is available. Thank you so much.
John Funk
Hi Vidya - Welcome to the Atlassian Community!
I suggest you use an app from the Marketplace. I know Kantega is a good one.
https://marketplace.atlassian.com/search?query=user%20management
Vidya VASUDEVAN
This is quite interesting.. I can propose this to my team if no budget involved but it seems again the budget constraints .. Let me check..Thank you so much
Like John Funk likes this
Nikola Perisic
Welcome to the community @Vidya VASUDEVAN
This is more feasible with Data Center with usage of ScriptRunner that has a dedicated script for deleting inactive users. On cloud, ScriptRunner is limited for this kind of a task. You can use the API where you would need the account_id of each user and you can bulk delete them just with one API call.
Furthermore,
Vidya VASUDEVAN
For cloud its quite difficult, also its for the team, I need to consider the budget for API again , I checked for marketyard but sadly we need approval for the API which is next to impossible.. But thank you for the information.. Good to know this information.. Thank you so much.
Nikola Perisic
You can also use this Manage Users for Jira Cloud
James June 17, 2025
Hi @Vidya VASUDEVAN ,
That's a common challenge. Jira's native automation can't fully handle deactivating users based on inactivity.
For a more robust solution, our tool, Seats Management, automates this process entirely. It's built to help with cost-saving and compliance for standards like ISO 27001 and SOC 2.
You can see how it works here: http://www.seatsmng.com/.
Happy to answer any questions.
