When i go to my administration I do not see Product Sandbox in my options
As per the internet it said to follow these steps
To create a sandbox:
Thanks for your help.
Denise
Hi Denise,
You'll need to select the Products menu item in the top navigation, and you should see the Sandbox page in the left navigation.
I don't see the same view. I know that we have a sandbox active for JSM, but I can't find where this is indicated.
I also wanted to know if I can get Jira sandbox working along with JSM. We have cloud premium across all products.
Do you currently have a sandbox already for that instance? If you do, then you will not see the option to create (another) sandbox.
admin.atlassian.com will show a section with a "SANDBOX" lozenge if you currently have a sandbox for that instance.
Otherwise, I find that I always get stuck here:
