I enabled the read:issue.transition:jira but error is returning
Fathima S H February 27, 2022
I am using Auth2 authentication for getting transition id.
I referred this document:
https://api.atlassian.com:443 "GET /ex/jira/{cloud_id}/rest/api/3/issue/{issue_id}/transitions HTTP/1.1" 403 None
Added the mentioned scopes in the code.
I am getting this error:
{'errorMessages': ['Access to the resource was denied due to missing scope grants. Your app was granted the following scopes: [read:status:jira, read:application-role:jira, read:project-category:jira, read:project:jira, read:field-configuration:jira, read:issue-type-transition:jira, write:issue:jira, read:issue-details:jira, read:issue-type-hierarchy:jira, write:issue.property:jira, read:user:jira, read:avatar:jira, read:issue-meta:jira, read:issue-type:jira, read:audit-log:jira, read:project.property:jira, read:project.component:jira, api_access, read:group:jira, read:project-version:jira].\nThe resource can be accessed by having one of these groups of:\n * current scopes: [read:status:jira, read:issue.transition:jira, read:field-configuration:jira]\n * deprecated scopes: [read:jira-work]\n']}
I enabled the read:issue.transition:jira in developer console and also added this scope in code. But that particular api is missing inn the error message.
Can anyone explain what I am doing wrong or do I need to enable any more scopes?
Below image has list of scopes that I enabled
Any help is much appreciated.
Thanks and regards
Vishnu March 4, 2022
Guess, the scope read:issue.transition:jira is replaced with api_access by JIRA API, Have you got this resolved? Experiencing the same with scope in my 3LO application.
Fathima S H March 4, 2022
Not resolved this issue
Like Vishnu likes this
Fathima S H March 10, 2022
@Vishnu , Do you know how to fix this issue?
Vishnu March 13, 2022
Actually, The bug is confirmed by the Atlassian team themselves and There is an active thread regarding this issue. If you like to know more, you can check here: Adding "read🏷jira" scope (which is required to get Labels) is causing errors in other APIs
Fathima S H March 14, 2022
Hi @Vishnu Thanks!
Vishnu March 16, 2022
@Fathima S H Guess it is fixed by now.
Like Fathima S H likes this
