I have used automation to create a task and need some help with error Could not find create meta dat
Clare Schwarz
April 30, 2020
I have created a simple automation to create an issue and copy from the parent issue the description, the assignee and the due date - I get the following error
Could not find create meta data for project/typeId -10113/10157
This automation is running for three projects all next gen and only occurs in one of them.
I cannot work out what is happening is anyone able to help?
John Funk
Hi Clare - Is everything exactly the same, just different projects? Do you have a single rule that runs against all 3 or do you have 3 separate rules?
Can you share a screenshot of the rule and the audit log for the error?
Clare Schwarz
May 2, 2020
Hi John - It is a single rule that runs across all three - I think that one of the projects did not like picking up the description from the trigger issue for some reason. I change this and it has worked now,
Thanks for your response
John Funk
Great - glad you got it to work! If this took care of the problem can you click on the Accept answer button above to close this one out? Thanks!
Raisa MacLeod July 27, 2020
It seems it also doesn't like Same Issue type as Trigger as well - is there a bug?
Like JB KH likes this
