This is a standard install of Confluence and Jira on linux server. I've followed the steps described here. -> https://confluence.atlassian.com/conf510/migrating-confluence-between-servers-829078379.html However, all I get is a white screen when I try to access Confluence on the new server. What am I missing? I have not yet tried to migrate Jira to this server.
I have copied the following folders to the new server.
/opt/atlassian/
/var/atlassian/application-data/confluence
Thank you for your help.
Mike
That log file ( /var/atlassian/application-data/confluence/logs/stlassian-confluence.log) is not showing anything current. I just restarted that server and the last entry is from Friday the 20th.
Is there another location?
Mike
Try the catalina.out under the confluence installation then. I am suspecting that the new Confluence home itself is not recognized.
Thank you Jobin. The catalina.out file showed impropper rights to the atlassian-confluence.log file. Corrected that part. Here is the first error.
2017-07-25 16:20:17,046 WARN [localhost-startStop-1] [org.springframework.beans.GenericTypeAwarePropertyDescriptor] getWriteMethodForActualAccess Invalid JavaBean property 'cacheFactory' being accessed! Ambiguous write methods found next to actually used [public void com.atlassian.confluence.spaces.persistence.dao.hibernate.HibernateSpaceDao.setCacheFactory(com.atlassian.vcache.VCacheFactory)]: [public void com.atlassian.confluence.core.persistence.hibernate.VersionedHibernateObjectDao.setCacheFactory(com.atlassian.cache.CacheFactory)]
I can post more of this file later if need be. Is there a way to post the file?
Thank you again.
Mike
Do you see any error in the logs (atlassian-confluence.log) during startup or while accessing confluence?
I do see some errors but I'm not sure how to translate them. Is there a way I can post the file here or should I find alternative methods.
I'm at a lost of what to do next.
Thank you
Mike
