I need help with a JQL query that can filter out my Test Executions based on the environment they are run on a daily report basis. Also, the report needs to exclude test execution for any retest.
The query that I'm using is
issuetype = Test AND issue in testExecutionTests('TestExecutionKey') AND updated > startOfDay() AND updated < now()
TestExecutionKey filter:
issuetype = "Test Execution" AND project=XX AND fixVersion = vNext AND sprint in openSprints()
It returns the previous execution test run status rather than current execution,
Can someone help me with it? any help would be appreciated.
Hello @kajaljena01 and welcome among us
I can suggest some modifications, I hope they can help you
Your issue is a Test or a Test Execution ?
Hi JM, thanks for your suggestion. I replaced 'updated' with 'created' field but it returns 0 results.
The fix version is correct and if I try to fetch the report from test execution (TestExecutionKey filter ) then report is matching but not when I use testExecutionTests('').
The issue type is Test, I'm trying to get a list of tests from Test execution. We have got multiple teams and multiple test executions created per sprint. We are using x-ray tool. I need to fetch test execution daily report for multiple projects with the same fix version and this should fetch first-time run tests only, excluding all retests for defects.
Ok so your tickets are already created before the daily test ?
In this case I can suggest to list all your project in your query :
Project in (ABC, AZE, QWE, etc...) AND fixversion = vNext AND issuetype = Test AND sprint in openSprints() AND updated > startOfDay()
Im using a similar query to get test executions.
Project in( X1, X,2) AND fixversion = vNext AND issuetype = Test AND sprint in openSprints() AND updated > startOfDay()
The report with Test execution is overall status and not daily basis. That's why I'm trying to get a list of tests executed on a daily basis and their status.
Normally team creates test execution for the environment with no test on sprint planning day itself.
Also, added a label in Test to identify failed tests so that filter will exclude if it rerun.
The query filter issuetype = Test AND issue in testExecutionTests(filterId) looked ok until I spot the failed test which failed last Oct but report shows for today.
I tried with different optional parameters for testExecutionTests but still, it didn't work.
Is there any other query to retrieve the test list from test executions
I tried with filter=TestExecutionkey but it still not working as expected.
For some unknown reason, it returned any previous execution where Test is attached to a defect, even though the defect itself has been closed already. Not picking the correct Test execution status.
