I want to add a management number column "Project name-xxx" before the "Project/Version/Ticket" columns in WBS Gantt-Chart. However, it seems that there is no option to add such a column in the settings. Unfortunately, it appears that this cannot be done.
Hello @Yukishige Chayama, welcome to the Community! 👋🏻
Thank you for posting - Raphael from WBS Gantt-Chart support team here 😊
You have 2 options to add custom columns (e.g. this management number you mentioned)
This should cover your needs, Yukishige. However don't hesitate to share with us if you have any other questions or comments on the matter, we'll be pleased to help! 🙌🏻
Kind Regards,
Raphael N. | Support Engineer
Ricksoft Support Team
Than you for your responce!
I would like to know if there is an item on the drop down list that automatically displays the "Project name-xxx" for that line. I understand it is possible to create by hand.
" Project name-xxx" can be created manually, but setting it up line by line is very hard work.
I appreciate your help very match!
Best Regards,
Yuki
Hi Yuki-san,
You can add the "Project name-xx" as a column on your Gantt, this way will display the name of your project in all lines of your Gantt! You can do this by accessing WBS Gantt-Chart Settings ⚙️ -> click on Gantt Configuration -> Columns tab -> search for Project field and add it to the context, as follows:
After that, you can go back to your Gantt and this new column will be set as the last column, then you can drag and drop this column to the best position that you prefer. Here's my example:
Please let me know if the above information meet your need, Yuki-san 🙂 nevertheless please share with us if you have other questions or concerns, we'll be happy to help you!
Kind Regards,
