Can I connect Jira ITSM to Sharepoint and bypass Confluence? Or is Confluence the only KB supported either directly or with a Confluence widget back to Sharepoint?
@Margot Sharapova , I haven't seen anything out of the box but there is a Sharepoint Connector by Communardo that may work for you.
https://support.communardo.de/display/SPCON
https://marketplace.atlassian.com/apps/235/sharepoint-connector-for-confluence?hosting=server&tab=overview
-pjd
@Margot Sharapova , Just saw you tag for Cloud. The add-on about is only for server. Sorry about that.
