Will creating Releases in Advanced Planning automatically create them in the boards that I am using as Issue Sources once I save changes in the Advanced Planning UI? Or will the Releases created in Advanced Planning just show in Advanced Planning?
Thanks!
Hi @Jorge Oliveros and welcome to the Community!
As long as you create that release linked to a project and then save the changes you make in your plan to Jira, yes it will.
Hope this helps!
Thank you!
