For first look qustion is very simple, but i don't know what is going on. I have two if else in my code. Create task and update custom field from transition post function in Create. Here is a code:
def type = issue.getIssueTypeId()
// ---------- CREATE TASK -------------
if (type == "11") // tylko dla IssueType = System
def sum = issue.getSummary()
issueInputParameters.with {
projectId = projectManager.getProjectObjByKey("SYS").id
summary = "$sum"
issueTypeId = "12"
reporterId = user.name
def validationResult = issueService.validateCreate(user, issueInputParameters)
def issueResult = issueService.create(user, validationResult)
def newIssue = issueResult.getIssue()
log.debug "$newIssue"
else
log.debug "Task nie został stworzony - IssueType inny niż System"
// ----------UPDATE RELACYJNY CUSTOM FIELD-----------
if (type == "11")
def fieldToChange = "customfield_11067"
def newValueIssueKey = "SYS-15810"
def cf = customFieldManager.getCustomFieldObject(fieldToChange)
List newValue = new ArrayList()
newValue.add(newValueIssueKey)
issue.setCustomFieldValue(cf, newValue)
log.debug "test2"
else
log.debug "Custom Field Not Updated - IssueType inny niż System"
Where is a problem? Task is created, but in logs i have:
Custom field is updated, but in logs i have:
I don't have test2 or $newIssue value. I think that could be very stupid mistake, but where... If works fine because Issue is created just for type == 11.
I believe your compiler hadn't gone through the if loop. The task got created and updated by some other mean. Use type.equals("11") method instead. Refer this.
https://www.geeksforgeeks.org/difference-equals-method-java/
Thanks for response! if I tried with equals("11") issue isn't created - just loading and nothing happens. I tried something else. I give to log.debug value "$type" and i have returned... 12 (when I creating 11).
Next I tried to Create another issue (another than 12 and 11) and in log i have good number - 14. So... Qustion is:
Possible is that when I creating issue with ID 11 IssueTypeID is somehow changing to new value and this deleting my loop?
EDIT: I Made this with equals, like this:
def typecorrect = "11"
if (type.equals(typecorrect))
but i have this same problem... Script Runner returning value from else and it is "12" not from If. Still creating issue and update issue.
Refer this and debug the first piece of code for creating ticket, code line by line.
CreateValidationResult createValidationResult = issueService.validateCreate(appUser, issueInputParameters);
if (createValidationResult.isValid())
IssueResult createResult = issueService.create(appUser, createValidationResult);
if (createResult.isValid())
Issue newIssue = createResult.getIssue();
def changeHolder = new DefaultIssueChangeHolder();
jiraTicket.updateValue(null, issue, new ModifiedValue(issue.getCustomFieldValue(jiraTicket), newIssue.getKey().toString()),changeHolder);
else{
log.error("could not create issue: " + createResult.getErrorCollection());
else{
log.error(createValidationResult.getErrorCollection())
I have added loggers on multiple loops for CreateValidationResult & IssueResult
