If linked issue then dont execute script on workflow
Rob B
March 12, 2018
We have a script that executes on the create transition of our workflow. This basically makes the user add a custom field. The problem we have is when they create this issue via the 'create linked issue' button the custom field is not on that screen hence they cannot create the case.
I know the linked issue screen cannot be changed, so is there a condition i can add to the script to stop it executing if the issue is created via the 'create linked issue'?
import com.opensymphony.workflow.InvalidInputException
def customFieldManager = ComponentAccessor.getCustomFieldManager();
def CustomFieldValue1 = issue.getCustomFieldValue(customFieldManager.getCustomFieldObjectByName("Retailer ID"));
if(CustomFieldValue1 == null) {
def CustomFieldValue2 = issue.getCustomFieldValue(customFieldManager.getCustomFieldObjectByName("Retailer ID List"));
if(CustomFieldValue2 == null){
invalidInputException = new InvalidInputException("Retailer ID Mandatory")
Alexey Matveev
March 12, 2018
You can hide the button using ScriptRunner web fragments: Hide system or plugin UI element
Rob B
March 12, 2018
Hide the 'create linked issue' button?
Alexey Matveev
March 12, 2018
Yes. You can write a condition for which project and issue types to hide
Rob B
March 12, 2018
Thats an option to have i guess. Cheers Alexey!
