If there are 2000 Jira users and 100 testers then which Zephyr licence should I use?
Chaitanya Kulkarni April 5, 2023
For example should we use Zephyr Squad, Zephyr Scale or Enterprise
Dave Mathijs
Hi @Chaitanya Kulkarni welcome to the Atlassian Community!
The number of licenses needed for an app is always equal to the highest user tier of a Jira product, even if only 10% of your users actually use that app.
So if you have a 2000 user tier for Jira Software, then you'll also need a 2000 user tier for Zephyr.
However, you indicated that your are on Server. Please note that it's no longer possible to buy server apps. You'll need to migrate either to Data Center or to Cloud to buy new apps.
Srush
April 5, 2023
Hi Dave,
For Jira Software data center, how to determine which particular Zephyr tool (Zephyr Squad, Zephyr Scale or Zephyr Enterprise) we should use for 2000 users where 100 of them are testers?
Dave Mathijs
This is what SmartBear says:
Zephyr Squad: Perfect for small Agile teams getting started with Test Management.
Zephyr Scale: Powerful solution with test planning, reporting, and reusability for growing teams working across multiple projects.
Like Srush likes this
Hello @Dave Mathijs  Thank you for the reply
What is the particular number of users  or range of users that signifies that we should use Zephyr Squad or Zephyr Scale?
Dave Mathijs
There is no particular number of users, it depends on the features needed for test management.  Scale has more features than Squad. Also think of pricing for this user tier.
Like # people like this
Nic Brough -Adaptavist-
April 5, 2023
The number of users that you will need to pay for will match your DC/Cloud install number of users.
If you think you only have 100 people who will be using it, Zephyr Squad could be the better choice, but I would look at Scale as well.  I tend to say Squad is almost always right for under 50 actively using it, Scale if you're over 250, but that is very generalised, and you really should compare them on features!
Like Chaitanya Kulkarni likes this
Fabio Racobaldo _Herzum_
Hi @Chaitanya Kulkarni ,
welcome to the Atlassian community!
Apps license should match the highest JIRA Apllication tier.
For example if you have JIRA Software with 500 users and JIRA Service Management with 100 agents, your apps need to have license for 500 users even if that app is specific for JSM.
Hope this helps,
Fabio
nedra felicia
April 5, 2023
it depend on highest user tier of a Jira product,
SERVER
