Import CSV File Issue in my JIRA Project
Sandeep September 5, 2019
I have created project but unfortunately i i can not able to import around 100 Test Cases  from CSV file. Please assist screenshot is attached for reference as well.
Sandeep
Inactive Stephen
September 5, 2019
Hi @Sandeep
It looks like from the screenshot you have either an issue type called "Test Case" or a (custom?) field called "Test Case" you need to load a Test Case ID into?
Assuming these Test Cases are issues - to use the issue importer, you need to provide at least a Summary (i.e the issue's title) to allow you to upload. This is because a Summary is a mandatory field - without it you cannot create an issue.
I would advise also if the Test Case is an Issue Type mapping the issue type also - if not, the uploader will default to the base issue type during creation (often this is "Story")
Ste
Sandeep September 7, 2019
@Inactive Stephen  Thanks for your feedback actually my requirement is that in KANBAN Board i have around 60 test cases and for each test test case and if any issue user wants to create it that can be embedded with test case. In KANBAN board we can track of it. In normal approach if i use Task/Issues based approach it will be difficult to manage. Please assist in this scenario as I am new in JIRA.
Inactive Stephen
September 8, 2019
Hi @Sandeep
Just to check - what are you tracking across the Kanban Board? You're tracking Test Cases across the columns - i.e these are the work items?
And it is Test Cases you want to upload? I.E each row on your CSV is a Test Case?
Ste
Sandeep September 9, 2019
Hi @Inactive Stephen thanks for your reply let me show you my requirment.
Step 1: We have to create test cases around 70.
Step2: We have to pick one test case and if it is pass then no need of action.
Step 3: If test case is failed then we to create issue in that test case.
Please advise.
Project We taken KANBAN.
