Hi
When importing issues from CSV file, it creates Epic and not Task.
how can it happened,
I did this few times and it created tasks.
can you assist?
When you are importing the tickets you can include a column for the Issue Type field which will be mapped out to Epic - the default ticket type for the project must be a task.
Additionally, you can use the Bulk edit to make them all Epics.
