Import Project Settings from Template project to project
SandeepSingh R
Hi Team,
I being Project manager made a Project template(Company Based) based on  process and created Workflow and ISSUE schemes,
I need to import same whenever i am creating new projects how can i do it.
I tried but failed
Mayuresh Kamble
November 24, 2024
Hi @SandeepSingh R ,
You can create the new project with shared configuration of the project which you want to copy all the configuration schemes.
  1. Select Projects in the navigation bat and then Create project
  2. Choose a category or product from the templates
  3. Select Use template
  4. Choose Company-managed as the project type
  5. Name the project
  6. Check the Share settings with an existing project checkbox
  7. Select the project to share the configuration from the Choose project dropdown
  8. Select Create
Hope this helps!
Mayuresh
SandeepSingh R
SandeepSingh R
@Lucas Knorr Please see the attachment
Lucas Knorr
November 24, 2024
Hi @SandeepSingh R
the solution to your problem is called "shared configuration". Basically when you create a project there is an option to share the configuration with an already existing project. This process is described here:  https://support.atlassian.com/jira-software-cloud/docs/create-a-new-project/
Christian Lakin Dick
January 20, 2025
Hi @Lucas, I'm struggling to find this functionality in Jira Work Management, can you confirm this is still an option? Following all the guides to the letter
