Is it possible to export a project that was originally created in ProjectLibre to Jira? I see that there are import options in Jira, but they seem to be importing other Jira-specific projects. So, I'm wondering if there's a way to take a ProjectLibre project and import that into Jira in a similar manner.
Thanks!
Assuming that projectlibre can export to CSV then you can certainly import the CSV into a project in Jira. Note you first need to create the project in Jira.
