I'm using automation and i wanted to know if it is possible using script to get informations from a ticket for which i know the id.
Hi @Admin Jira and welcome to the community!
It would help to have a little more context around what the goal(s) you're trying to achieve such as what is triggering this and what actions you want to take on the issue. This will enable us to point you in the right direction.
I'm using Xray and i want that when a test execution is added to a test plan, the test execution inherit the test plan's components. The problem is, it is not really a link between these two entities, so i don't know how to get the test plan informations from the test execution.
The test execution has an attribute 'test plan' containing the id of the test plan to which it is linked. So this is the trigger of my rule, whenever this value change, i want the components of the test plan to get inherited to the test execution.
As i don't know how to get the components of the test plan from there, i was wondering if it is possible to get this information using the test plan id (that i got) in a script
I'm not 100% familiar with XRay so I'll have to defer to my community colleagues on this one.
