Hi Team,
We have few documentation related to JIRA tickets in Confluence / Sharepoint. We manually setup links to these artifacts in JIRA tickets. Is there a way to do so using Automation for JIRA? I found a comment from Andreas Knecht from 2020 that it was not supported until Aug 2020. Has there by any changes meanwhile? Has anyone got it working with A4J?
Thanks for your insights and feedback,
Janaki.
Automation can fill in a link field, or put links into text fields. Where exactly are you stuck?
Thank you for your reply. I believe you are referring to the URL field which behaves as a Custom field.
The one I am looking to update using A4J is the below
Hello. Have you figured it out how to solve this? :)
Thanks!
